Chasing a freeway speed vibration.
Glendale, AZ
I have a vibration starting at 70mph that goes through the whole body of the vehicle, kind of like a drivshaft vibration. I put new ujoints in and am in the process of getting both shafts straightend and balanced.
I have new front bearings, brakes and rotors.
Also, I got some new rear rotors to put on.
Do the rear axle bearings get lubrication from the diff gear oil or to they have to be greased like the front? Could these bearings be worn out causing the vibration?
Did you look at the drivetrain issues thread in the maintenance section of the FAQ? I believe there is a compilation of many different issues and some may be applicable.
Best way to troubleshoot is to engage the CDL and drive with only one drive shaft at a time to see if its front or rear
Ok, thanks, I'll check it out.
Alco, to answer your question about the rear diff, it does have a hub assembly which houses some bearings that do require you to grease up using MP grease, the diff gear oil never makes it to the hub assembly..
Describing your setup may help folks diag. your issue...... lift, tires, mods, has truck been wrecked????
Also thing to consider most speed limits are 70 mph...... if it starts there, thats ok.....:confused::confused::confused:
I had the tires rebalanced 2 weeks ago chasing a front end shimmy at 60mph. This turned out to be the front wheel bearings. The front end shimmy is now gone.
Once you get far enough out of town in AZ on the main highways, the speed limits are 75. So people drive 75-90, like along I40, I10, and parts of I17. For me and my truck, 65 to 75 will be fine. Mileage will be a little worse and I will also use more oil.
My '93 is stock and patchy dark green. It's just got the stock Michelins on it. It's never been wrecked, and has 204,000miles on it. I'll probably do some mods later when I get some money. Right now I'm still baselining the basic maintenance stuff.
I just put both drivelines back in after they were at the shop so I'll see if this did the trick.
When I do the rear rotors in a couple of days I'll do a axle bearing inspection repack too.
Well, it seems smoother throughout the regular driving speeds.
But it still starts to vibrate >70mph, just not as bad as before. I'm wondering that since the front bearings were bad the rear axle bearings may also need quick attention.
I think I've read here also that rear rotor warpage can cause vibration.
Maybe I'm being too particular having recently owned a IS250.
For what it's worth, I've owned and driven 80s for nearly 300,000 miles total and there's an inherent high frequency suspension/body/frame jiggle that is unfortunately matched in frequency to a lot of freeway driving. For instance, I live in N. Idaho and the 30 miles of freeway between here and Spokane causes my 93 to feel like I have a tire out of round/balance at 70-80mph. On those times I journey beyond Spokane, it suddenly is gone and there is no speed at which the truck does anything but perfectly smooth running. Absolutely perfect.
Having done a lot of tuning on vehicle suspensions, I think the 93 has an unfortunate tendancy to develop this sympathetic resonation after its bushings and body mounts have hardened with age and the springs have aged a bit. I think many here have spent a lot of money chasing it with CV joints, and exactly the stuff you're contemplating spending money on. You may have freeways with similar characteristics. I find them all over the US. The truck runs perfectly smooth for hundreds of miles and then I pass through an urban area with a different road contractor and I'm jiggling for a couple hours. Unfortunately, I live in a jiggle area too.
The 97 does not do this at the exact same mileage so perhaps later NVH and suspension tuning removed this. My suggestion is on your next long road trip if you find that suddenly the truck is running perfectly smooth then you can chalk it up to this phenomenon. In other words, if you can find a stretch of road the truck runs smooth on then your mechanics are all fine. It's a road issue and it's unfortunate.
DougM
Interesting observation. You know, it does seem like it's resonating at those speeds and not just one constant vibration.
And now that I think of it, last week on a road trip on I17, all of a sudden when I was climbing a hill under throttle the vibration stopped for a short period. This did not repeat on the next hill though.
I'm going to go check out the Indian ruins at Mesa Verde in southwest CO soon, this will be about a 1000mile roadtrip, and I'll keep track of this on different highway pavements to see what happens.
I have just gone thru the nearly same situation. A rough, harmonic vibration usually under load at or passed 55mph. Had all tires re-checked< after a cross country trip,:steer: I had lost 6oz of weights>. Problem still existed, though just a little less harmonics.
Went to the local stealer and a few days l8r, I had a new front propeller shaft that solved the prob. I did know of a prev. condition with one of the u-joints on that shaft and had both u-joints replaced before determining the shaft had the issue.:doh:
1994 / 175k
Wow! The FAQ contains a wealth of information and pics. I'll be going there first before asking general questions in the future. Thanks!
DougM
My '96 does the exact same thing. I thought it was loose lugs but they are fine. Then I just assumed it was mud tires resonating at highway speeds. Interesting. I don't even notice the jiggle much now.
I ordered the rear axle hub bearings, seals, and gaskets along with a SST from CDAN and a FSM from the materials center(it's about time I get one of these i'm tired of the crappy haynes manual). So I'll put this stuff on and the new rotors to see if it makes any difference. I'll report back when this stuff is all on and may have to chalk it up to sympathetic vibration.
Maybe I'll try some suspension stuff in the future also.
Here's a follow up to this thread (Sorry it took so long but I refuse to do any auto work but emergencies and oil changes during the Az summer):
Replacement of the rear rotors with new ones seems to have cleared up most of the vibration from 70 - 80 mph. There is still some just above 70 - 75 mph but it has diminished quite a bit. I tested it on different types of road surface. I believe the old rotors were originals. They were extremely worn.
I also replaced the rear bearings/seals/ect. The old ones were original KOYO (210k mi) and did not look too bad.
I also replaced the parking brake shoes and did the rear brakes (obviously).
So it seems that the remaining light vibration is probably sympathetic in form.
I am quite pleased at the improvement realized by changing the rear rotors.
Did you also replace or rebuild the rear calipers?
No, but all 4 on the vehicle probably need to be done. They are probably original too.
I'm planing on rebuilding them next pad change. I get about ~15 to 20k mi for the fronts and ~ 30K mi for the rears. Hopefully they will last till then.
I too chased a vibration around for a while. Turned out to be siezed rear calipers. Once I rebuilt them they would release properly and 80% of the vibes went away. I'm still irritated by the remaining 20% though...
That's interesting, maybe I have a caliper issue contributing also. They seemed to move Ok with the c-clamp, but at 210k who knows.
I'll check with CDAN about the rebuild kits, I don't think they cost too much.
When I do the calipers I'll follow up and report.
Often rotors are warped/damaged because of the caliper not moving smoothly.
Buying new rotors and not R&Ring the calipers means you end up just buying a new rotor, because the sticking caliper will cause it to wear unevenly.
I noticed a huge different in braking capability after I did the :princess: truck with new (reman) rear calipers, rotors, and pads. And that was at 135k.
