12/78 FJ40
2F
Stock Alt, stock regulator
I've spent some time searching, but have not seen syptoms like mine.
I just got the Cruiser running again after sitting for 18 months or so. I ran it at the 2004 GSMTR with dual batts and found myself having to combine them to start more and more.
Today, I installed a single battery and hooked it up as original. The alternator has been tested and is good.
While at idle the battery shows 12.2V. With the RPMs increased I could only get the voltage up to 12.4.
Drove a couple miles and the ammeter stayed in the positive range, but barely.
Does the fact that the voltage rose even a little bit indicate that the alternator is trying but the voltage regulator may be to blame?
Could the dual batteries have killed it then?
I am going to go back to dual batteries and hook up the winch for GSMTR this year. I want to figure this out so I know...but I may take this as an oppurtinity to install an internally regulated Delco alt.
2F
