Charcoal Cannister
Near Junk
Need some quick help as I hook up a charcoal cannister on my '76 40. Did some searching and now know where its supposed to be located but not sure about hook-up. The cannister I have has one port on one end and 2 ports on other end.
I get that the tank line (from the fuel separator I just hooked up) goes to one of these ports. I think one is supposed to go to my intake manifold but not sure where and I have a weber carb on it so don't know what to do with that one.
The last one is a mystery - I guess it goes either back to tank (return line) or does it just vent to open air via a line I should run down beneath the frame?
Found this pic on-line though not sure if this is accurate for my year 40.
TIA,
AndrewT
TIA,
AndrewT
Yes, that is really close for a '76. The only additional piece is a one way check valve between the separator and the charcoal cannister for '76.
The OEM manual suggests replacing them every 50,000 mi.
Bwaa HaHaHa :flipoff2:
Pinhead - I thought that the check valve is in the cannister and not an in-line unit.
AndrewT
Pin_Head said:
On my 5/76, the check valve is a separate item in the vent line where it goes through the floor behind the B pillar.
Yeah - I thought so also but can't find it in emissions schematics nor is it on SOR as a part in their schematics. Hmmmmmmmmmmm.
PH - So I have gotten to the point where I know the cannister mounts with the end that has the one port on the bottom - and that this port is a drain which should run via hard-line down under the cab and vent to open air - maybe put a gas filter on end to prevent crap from going into it.
On the other end of the cannister there are two ports. One of them connects to the fuel separator from the tank with check valve in between I guess. The other line is supposed to go to VSV/intake which I don't have on my de-smogged weber set-up. Any clue what to do with this other line?
AndrewT
FYI - This is info I found from the web (Autozone site for repair info). This is why I thought the check valve is in the charcoal cannister.
Checking the Charcoal Canister and Check Valves
Remove the charcoal canister from the engine compartment and visually inspect it for cracks or other damage.
Check for stuck check valves. All Pick-Ups from 1970-78 have one check valve in the line between the fuel tank and the charcoal canister. It is located in the rear area. To check:
Remove the check valve from the line.
Mark which end goes toward the fuel tank and which end goes toward the charcoal canister.
Blow into the fuel tank end. A slight resistance should be felt at first.
Blow through the other end. No resistance should be felt at all.
If your results differ from those above, the check valve will require replacement.
1970-87 Land Cruisers have one check valve located in the canister.
1979-88 Pick-Ups with a carburetor and 1988 Land Cruisers have two check valves, both are located in the charcoal canister.
1983-88 Pick-Ups with fuel injection have three check valves in the canister.
AndrewT
I wouldn't worry about the drain tube.
Here is a link to the vacuum diagram:
http://members.cox.net/cglabe1/Photos/vacuum.JPG
I believe that the charcoal cannister is vented to intake manifold vacuum via the VSV, but I don't know that just hooking up the line to manifold vacuum is a good idea. If it was, Toyota would have done it instead of putting it under electronic control.
Agree with you that it does not seem to make sense to hook up to intake manifold without VSV. Since I don't have the other smog components and don't plan to rebuild (just want cannister to assist in tank venting) - do you think I can cap off this line?
I believe that the connection to the intake via VSV was designed as such to push gas vapor into the intake for combustion as opposed to just venting it. I would think that capping this would still allow tank venting with the cannister - I just wouldn't get the added advantage of also using the gas vapors for combustion via the intake. Do you see any issues I am missing?
Really appreciate your help here.
AndrewT
Sorry about hijacking, but I guess this adds to this post. What would be the disadvantage to running the purge line into the intake/plenum without a vac switching valve?
Just curious, I just finished redoing the entire vent system on my 69 piggy to match the 79 tank vents. On mine the canister I got said purge in small print under one outlet. THis one had a small 1/8" nipple, while the intake was a 5/16". I just ran this straight to the adapter plate under my carb insulator (hipo manifold to single barrel carb). Am I doing somthing that can cause ill effects? Initially, I just had that line capped.
I am running a check valve right past the fuel seperator, just because the diagrams always have one or two. Why run a check valve here? Is there really a concern of a siphoning effect?
And I guess a canister only needs to be changed if it gets clogged, I've never replaced one with a new unit and do not know anyone that ever has.
I never bothered figuring out how the venting works or what the VSV does, so I can't comment on whether just hooking the line up to manifold vacuum would be bad or not. Hooking anything up to vacuum represents a potential vacuum leak and it may result in a lean condition with poor idling and the potential of burning a valve.
