Charcoal cannister hooks to a computer??
Gig Harbor, WA
What is the electronic looking device that is connected to the charcoal cannister via a line running across the firewall?? The line from the cannister to the tank is capped off, so whats the other end do? Can i junk it?
It would help to post the year, model, and other details of your truck.
Sounds like you are asking about the VSV. It's the main switching valve for all of the smog control functions. You say the line from the tank to the cannister is blanked. What about the rest of your smog gear?
Pics?
Good luck
Scott
What you're describing is probably the solenoid valve that switches the canister to from the carb on/off. When the truck is on the solenoid opens and the the carb "sucks" the accumulated gas fumes from the canister. When the truck is off the valve closes and the canister accumulates the fumes.
Sorry. Its a '72 FJ40, 2f motor from a 78 fj40. The line from the cannister that cross the firewall to the driver side and ends at a little black box with wires, and a tube or 2 coming out of it. The fuel line from canister to fuel tank is crimped off at the fuel tank.
mmm i dont really think the word computer was in their vocabulary when the built 40's....im not realy sure what it could be
Its electronic, has wires goin to it. I think im just gonna start unpluggin crap and see what happens.
In Toyota lingo it's the/a VSV (vacuum switching valve) that opens the charcoal canister to the carb when the trucks running and closes the canister to accumulate gas fumes then the truck is not running.
