Charcoal canister rebuild - 80 Series
Do you think you’ll still have the truck in 2050 when it needs to be done again:hillbilly:
Fair, but since it is going to my 27 year old daughter who loves the thing there is both an outside chance and an interest. But you are probably correct, do it once well and be done with it.
I’m in the process of “rebuilding” mine right now. Temporarily I put on one of the $35 Chinese units and this has cured the tank pressure/de-pressuring issues.
I am ready to re-assemble the original unit and am wondering if it is really all that essential to get an airtight seal on the canister top? I have limited tools (hand/small electric) so welding is out of the question. I can do epoxy or RTV, but a full bead of either would make it pretty tough to get apart again.
The car has to go through the Colorado “front range” emissions test, so I’m counting on using the plastic cap to hide my work.
I would be grateful for any thoughts.
I'm intrigued ... what $35 Chinese units? Change it with my air cleaner each year?
Thanks. Looks like I'll just go straight to the rebuild -- doesn't look too difficult (but famous last words).
Not a difficult job at all. The Maple Syrup filters were very close to perfect.
The future of the car is going to include a fair number of trips from 5,000' in Denver to climbing areas in the upper reaches of the RMNP. I thought a functional breather was a good idea.
Is either a VC120 or GM GENUINE 215153 canister an option to you?
I run the GM Canister in most my 80s but working on a couple that I would like to stay stock.
I don’t have the time or patience to do the Canister rebuild so outsourcing it is my best bet right now for my needs.
Just did mine, DM me if interested.
I just cleaned the original filters with a CDA blower. 2500 miles since rebuild 👍
Honestly, I used a bag from petsmart there was more than enough and I sort of marked the level of the original inside the can as my gauge.
A bit of speculation but if you simply drill out the bb valve you are probably go to go.
I think there was a 1lb box at Petsmart, mix some of the old stuff with it if that’s not enough. I was getting it in a 12lb bag when I was doing these for people.
Also I totally support drilling out the bb and spring. Just grab a 1/4 drill bit and it only takes a sec.
I just rebuilt one for myself this week 👍
Just rebuilt one this week. Used less than half the charcoal I got from the pet store. If you come through Flagstaff the rest is yours.
anyone mind cluing me in to the options here but also what the charcoal canister does? also i'm gathering if it builds pressure in the tank i need to do something? (1) buy VC120 and retrofit it into OEM clamp/space (2) rebuild or buy a rebuilt OEM with a bag of new charcoal? (3) drill out the BB or something in your existing one (any links to this mod)?
THANKS
THANKS
Search for Landcruiserphil, his is the original thread on this topic. I started with a Chinese clone of the VC 120 but did not love the fit. I then ground off the lid to the original with an angle grinder and flap wheel. IIRC there are two paper filter elements that I replaced with material from maple syrup filters available on line and the charcoal from Petsmart. Looking at the lid, the place to drill out the BB is pretty obvious and I was done. I used RTV to seal it up which was probably not the best idea.
All in all, an easy job I wanted to do because the car routinely goes from Denver to higher elevations now.
I rebuild 2 of my canisters per LCP instructions.....by drilling out the BB. No issues since the mod....no smells, no hissing nor pressure.
