Changing my shocks
Philadelphia, PA
I have a totally stock (height) 1980 FJ-40 and I am putting new toyota shocks on. First time on the 40 I am doing this. Any opinions on how hard it is to loosen the bolts and pins? Do I need alot of pre-oiling as in the spring pins or is it fairly easy to get these off?
It's usualy pretty easy to remove all of the hardware for shocks. There are cotter pins to take out at each end of each shock. Nice simple straightforward job. 17mm wrenches, pair of sidecutters and go!
I did mine last weekend. It was a lot easier then I thought it would be. I used some PB Blaster on the back ones, and that turned out to be totally unnessisary. I didn't PB Blaster the front ones, or take the tires off on the front and did them in about 10 minutes. The pins came out very easy, and the bolts too.
Good luck... :cheers:
Hey John, how much did the OEM shocks cost you? Did you get them from the dealer? I went around and around with the dealer, and the price changed about 5 times. They ended up being quite a bit more then I thought they should have been. :mad:
Believe it or not, I got them cheaper from Cool Cruisers, $32 each. My Toyota dealer wanted around 45 and he had to special order them.
I think for a stock vehicle they are great. For 40's with a lot of lift, you are better off aftermarket.
