Houston (or Jerryvi) we have a problem!
For more info click here: -►
Clusters, Gauges, Speedo & Odo meters
Your "old" cluster is a pre 1980 model in Miles, with a VSS (Vehicle Speed Sensor) and a 30-0-30 Ammeter.
Your "new" cluster is a 1980 and later model in Kilometers, No VSS and a 50-0-50 Ammeter.
The High Beam indicator circuit is a little bit different hooked up.
- Miles vs Km is not the biggest problem.
- Yes or no VSS can be a problem because you may need that VSS signal for your desmog circuit.
- The High Beam indicator circuit can easily corrected.
- The Ammeter circuit is your biggest problem.
On your old cluster the total current of all circuits goes through the Ammeter (the 2 studs on the back).
In the new cluster the total current A goes through a fusible link and only a portion B goes trough the Ammeter (the 2 horizontal tabs of the 3 prong connector). The vertical tab is ground for the High Beam indicator light.
This is not easy to solve because you don't have the (special) fusible link, fuse box and wiring in your truck.
The easiest way is to return the cluster and buy the correct one.
Rudi
