Chad's slider build
Terre Haute, IN
Website
www.myspace.com
Well the PO of my 76 40 did a lot of things nice and some not so. The sliders (should be called damage multipliers) are one of the things he didn't do so great. I am taking it on the trail for the first time easter weekend so I had to d something about these.
Here's a pic of the PO's idea of a slider.
Here is what I am doing to replace them. The steel is 2x2 3/16's. I took several pics with the tape measure in the pic in case anyone wanted to do something similar. I will post up pics tomorrow of the finished product welded in place with gussets. I think these will be tons stronger. Let me know what you think, so that I might make any changes before I weld them on tomorrow.
Here's the pics with the measurements.
Here's a drawing of how I am going to make the gussets. I will weld one of these to the bottom of each leg and to the frame, I would put one above the leg as well. Do to my 2" body lift the I have to weld the sliders to the frame right at the top edge of the frame.
Here's tonights pics of the finished product. It got dark on me before I could get any good pics, I'll take some better ones tomorrow.
Whelp, you've sacrificed some clearance for some serious strength. Not a bad trade-off, as slider designs go. Consider adding a gusset affixing the slider to the body mount bracket to prevent bend up of the slider and possible tweaking of the frame rail (though probably unlikely along the boxed section).
:beer: for home fabbing some tough sliders.
Excellent idea I believe I will add that gusset tomorrow.
Another unsolicited suggestion:
Using the threaded holes in the body mount bracket, bolt on a bracket for the gusset and then fab the rest of the gusset to go from the bolt-on bracket to the slider. This will avoid having to weld in awkward positions and will enable the removal of the sliders (for "improvements":D) by only grinding off the welds on the frame rails and unbolting the rest.
Here's the gusset from the body mount to the outriger. I think I am going to put another piece of 2x2 from the rear outriger back to the frame at an angle.
Those look really nice, and I like how you retained the stock step.
Nice looking stuff.
Rezarf <><
Nice job Chad. Looking forward to joining you in testing them out Saturday. Just might have to make a pair of those myself. They look really stout.
clean. we made some with round stock, but I like that square stock you used as I think angles are cooler and those turned out nice.
I especially like that overspray onto your nice stock step, frame rail and body mount :)
