Wanted Central Florida: Hazard Warning Light Switch
Status
Not open for further replies.
FloridaLife
Florida
  1. 40 Series
I am looking for a Hazard Warning Light Switch for my 1971 (build date Dec '70) FJ40.
I need one from these build dates please: 7/70-9/72
Attached are 2 pics for examples. It is the small red pull switch just to the left of the cigarette lighter.
Thank you.
Thank you.
- I have both NOS and Professionally Restored inside and out 1st Gen. HAZARD pull switch boxes ..
- Either choice above can come nicely saddled up with my period correct fit form and function reproduction Red-Bell 1st Generation HAZARD knob as well as you show clearly in your nice tech photos above …
My hand-made in-house Red HAZARD knobs have a solid brass female threads thick and meaty core , as well as a female threaded same traditional set-screw set-up same as the original ones did …
Both the Red HAZARD knob and my period correct H / Heater Blower front and rear Fan Pull knobs are Not 3-D printed , rather I craft them the traditional TOYOTA way , by hand , with pride using Kustom CNC alloy molds made from NOS originals of each knob outlined above ..
The Correct original OEM RED Color was based on a NOS Color Sales Brochure shot with KODAK KODA-CHROME Color slides and stored in a archival jacket sleeve I purchased in 1989 at the Carlisle Auto Parts Fall Swap meet and show in Carlisle Pennsylvania….
Oh Yea … it’s spot on HAZARD Red period correct little WONKA gum ball for sure …
I will post photos below shortly …,
Thanks
Matt
7/70 Toyota changed the wiring so instead of the hazards and turn signals each having a flasher unit to sharing one. The switch changed at that time. I show 9/72- 9/73 having a one year switch. So you time frame you would want a switch from 7/70-9/72. Unfortunately I'm not organized because I stripped the wiring from a couple of 71s back in the 1990s.
Thank you for the information. Your wife does not have you organized yet? The pics of your parts stash looked pretty well organized to me. 👍
Thank you.
84330SWITCH ASSY, HAZARD WARNING SIGNAL
84330-60010(03/1969 - 06/1970)
84330-60020(07/1970 - 08/1972)
84330-60040(09/1972 - 08/1973)
Matt why is it I'll find some sites with parts as a mid month change where the old and new show starting and ending on the same month. Example is the 73 model. Find previous model ending 9/72 which find the start of the 73 model. Same way for 9/73. Most sites show 78 ending 1/79 but have never seen a 1/79 with the 78 style tub.
Thank you.
here are my currently available and ready to ship out same day / next day ( i have a 3:30 pm EST time zone cut-off for a manual special order like this is )
fyi
- all below are NOS ( new old stock ) the one with the longer pigtail is a FJ40 , without long pigtails are FJ55 ( split production date 55 thing ) both are plug & play interchangeable , the FJ40 land cruiser you have , the wire harness behind your COWL switch panel , is long enough harness side female plug to reach the fixed-connector 55 HAZARD switches .... you can choose either style , there All new / NOS and i have also bench tested each one as i do ALL electrical parts that leave my shop sent to your shop ....
- i have my in-house hand-crafted by me personally Harness side Service Spec. repair connector pig-tail kits available seperatly if you happen to need one due to a burned up harness side plug or amy of the wires ?
Do you already have the Red Bell knob or do you Also need this as well ?
I have all 3 different pin wrench nuts , you may choose any style you like ….
note : the switch in the back ground is a pre-owned one that I have Not done my routine inside and out professional restore on yet …it’s for cross comparison purpose's for you …fyi
I do not have any restored ones ready to be shipped out right away at the moment …fyi
thanks !
matt
So @FloridaLife are you needing the switch that has a 6 terminal plug with 7th bullet end wire or a 9 small terminal plug?
@pardion according to @Living in the Past what I need is a Hazard Switch that was made from 7/70 - 9/72 (my FJ40 was built 12/70), and if I am understanding @ToyotaMatt correctly it is a 9 pin plug, and the switch part number is 84330-60020.
Speaking of the WONKA red gumball pull knob, I should put a label on the dash under it that says "Ejection Seat".
fyi
thanks !
matt
View attachment 3741029View attachment 3741030View attachment 3741031View attachment 3741032View attachment 3741033View attachment 3741034View attachment 3741035View attachment 3741036View attachment 3741037View attachment 3741029View attachment 3741030View attachment 3741031View attachment 3741032View attachment 3741033View attachment 3741034View attachment 3741035View attachment 3741036View attachment 3741037
What got me on this topic was looking at the photos of my FJ40 and noticing a spot on the dash to the left of the cig lighter that was just a blank empty hole, and trying to find out what should be there. So, I'm missing the whole thing, including pull knob and nut.
Depending on when I feel up to it, I'm going to go over to the shop where it is either tomorrow afternoon or Saturday morning to try to work on the EPS conversion. While there, I will look under the dash where you (ToyotaMatt) said to look and see if I can find the plug. Right now everything is a bit of a mess, with everything pulled out of the dash for paint & body.
if your Engine Bay DATA ID Plate is stamped :
- FJ40L-A ( FST )
- FJ40LV-A ( VAN / HARD-TOP )
- and your drivers side door jamb A-Pillar DATA ID Plate is Stamped Dec. 1970 or 12 / 70
- then you do / should only have a 84330-60020 as i outline and show above , there is zero grey area here , providing your Pro-Date and Model ID Code are as you make clear in your Thread Starter Post # 1
- FJ40L-A ( FST )
As for the engine bay data plate, I don't know since it is at the paint and body shop. The drivetrain is out of it so next time I'm over there I can look, if you tell me where to look. The passenger side. But let me know. As for the VIN and data plate on the door jamb, that's definitely what it says and here is a pic, see attached:
Well 7/70-9/72 did not have a Red pull knob. It’s black with a red engraved car. Here’s a couple photos stolen from the dash thread. I hope this helps your search. John View attachment 3741187View attachment 3741188
TOYOTA Never Offered the 84330-60020 HAZARD Switch Knob separately .......... only came with the switch as a KIT together .
so mr. pardion is the authority here ... :) :wrench: :wrench: :wrench:
Status
