Centering the front axle
I was replacing the lateral arm bushings. I thought, no sweat, just take off the adjustable lateral arm, don’t move anything, press the bushings, put it back.
If it was centered before, it will still be centered.
But I’d like to double check, before I call it good.
Is it best to jack up the front end, put jack stands under the frame so the front axle is hanging, or better have weight on the axle so it’s in “game situation” to jigger things ?
What two points do you use to measure the side to side ?
Has to be weighted and on the ground, otherwise your panhard bar will pull it over to one side.
Compare C'line of frame to C'line of axle, use a plumb bob to find C'line of frame at both ends of rig, transfer to drive way and snap a chalk line. Find c'line of axle, transfer to ground with plumb bob and compare.
For us older fat guys, its a lot up-down, roll around and grunting.
So I just did this and i can tell you what I ran into.. I jacked up the cruiser just a bit not all the way. Wheels were still on the ground. I then put a few jackstands under the frame. Now you can remove the control arms.. I did one side at a time. My plan was to keep the wheels straight and remove the arm. Well that all went out the door when I found out you will not be able to remove the front two bolts without turning the wheels due to the limited space between the nut and the brake backing plate. Once I did this I was able to access the bolts. Removed them and the arm came out no problems. Pressed out and in the new bushings no problems. Now installing the arm was a bit of a pain as the axle had shifted a bit and the holes would not line up. Turning the steering wheel will help line it up. I was able to get the rear bolt installed and the front bolt. However the middle one would not line up. I had to get creative with how to get it to line up. A few pry bars to pry down on the arm shifted the bushing down and I used a long punch to insert into the bushing and move it around until the bolt went through.. Some people use ratchet straps to pull the axle in the direction they need to line it up.. I did not have to resort to that.. Good luck.. Oh btw don't tighten the bolts untill you have all three in.. Check out the instructions I made for myself to follow at this link:
Strange, I did not have to do that replacing my control arms a couple weeks ago. I couldn't fit my impact wrench on it of course but there was plenty of space for a breaker bar and socket. The ratchet strap method was actually quite easy to control fore/aft alignment, along with the floor jack to raise or lower the control arms.
Also, was your rear bolt head really a 24mm (in your instructions)? On mine for both the original and the replacement, the bolt head was 22mm and the nut was 24mm.
I guess I should have specified I used an impact to remove the front bolts.. I may try the breaker bar method on the driver side which I'll hopefully get to this weekend. Yeah I just checked and my rear bolts are both 24mm.. I have a 1993 though maybe that is the difference? I can tell ya on the 93 and 94's you will have some issues removing the bolt because the cats are in the way. Some folks just cut the bolt. But I wanted to re-use mine.. I was able to place a block of wood on my jack and jack up the cats.. There is plenty of flexibility in the exhaust hangers it moved out of the way just enough to slide the bolt out. I installed it the opposite way with the nut facing the cats so it will be easier to remove in the future..
Pretty sure the OP is talking about the panhard bar. If that is the case, easy peasy. Pull it out, press in new bushings, put it back in. You may have to have a buddy push the truck side to side a bit to get it back in, but that is only if it moves slightly after removal. I have done a few single handed. Its really pretty easy.
Or just turn the steering wheel. That will shift the body back and forth really easily.
Yeah this is how I did it and it worked great.. And I did not jack anything up when removing the track bar just leave the full weight of the vehicle on the ground. Sorry I did not read close enough on the OP's original post.. Lateral vs.. leading
Yep, just pull them off and put them back on. I had to shove on the fender to get the bolt holes to line up. No sweat :)
