Here is how i modified my console, i needed more of an arm rest and added cup holders. I cut out the existing center section, put 3/4" ply underneath and bondo'd around 2 cups, it still needs a little sanding and the bed lining finish. i took the cup holder on the side and moved to the back, to make room for the arm rest. The arm rest is a 2x4 box slightly larger then the top, with 3/4" ply shaped to fit nicely around the e brake, then covered with foam and some material. Maybe this will spark some ideas for others
