So I finally got my center arm off. I bought a pitman arm remover and widened the mouth a bit and tapered the thickness of the two fingers and it slipped right in it worked.
No I have the bracket assembly in pieces on my bench and have a few questions.
1. the rebuild kit has a seal that is different in design than the oem I took off. The oem has a metal ring on the bottom side, the new one doesn't. Is the metal ring supposed to be reused and the rubber inside replaced?
2. The tapered bushing has tab that loks as though it gets bent into to grease inlet to keep it from spinning. Is this the case?
The inside of the housing has some minor rust so I guess the seal must have failed. The grease was quite dirty, although I do add to it occassionally. Hopefully the rebuild will eliminate some of the play in my steering.
Looking forward to replies.
Thanks, 45Kevin
Thanks, 45Kevin
