Hi Jonheld,
the blue fusible link was blown. I have been checking to see if it had a bad ground or shorted out wire but i couldn't find anything in the harness. It all appears to be good as far as wiring. I checked the alternator for proper grounding and it all appears good, all the wires coming from the coil appear to be in good order, no frayed or damaged wires in the firewall, both o2 sensors are good and the wires are good as well, the CEL light was good, the printed circuit on the dash is good. i've not messed with the AFM/MAF.
At this point i dont know what else to check.
The truck just stopped running while i was on the freeway. The fusible link was blown and so was the fuse. The ECU does not appear to have any external damage such as a blown resistor or capacitor. I did check the resistor that a couple of people have posted before where it was physically damaged but it checked out fine at 2.3 OHMS +-5%.
I ordered a new to me ECU and should be getting it this week.
The cruiser has 296K on the clock, was hoping to get it to 300k. i've had the truck for about 15 years, im the second owner. it's not a daily driver but i take it out every couple of weeks to go camping and stuff, never had any issues aside from bad starter, alternator or battery.
The only thing i did recently, about 4 weeks, was to install new shocks and springs.
Thank you for any input.
