cel 25 and 26 advice please
Western New York State
First let me say I read all the existing threads on my problem and appreciate all the advice which is so readily available. But I almost feel like there's so much information that I'm lost as to the steps I should take and in what order. My 94 lc ran fine before the winter except while idling at a red light the idle would drop and stumble and then go back up again. Recently the cel went on with 25 and 26 codes (lean and rich air fuel mixture) and the engine runs horribly with occasional strong fuel odors. The question is where do I start? Should I change the plugs and pcv first then move on to a full tuneup before worrying about O2 sensors? Last tuneup was over 2 yrs/ maybe 20k ago. The vacuum lines appear fine. Any advice on the procedure to follow would be helpful. Thanks.
Check air intake hose for cracks first, then check 02 sensor plugs for water/corrosion.
exactly what i said in my post. But let me ay, dont CHECK the plugs for corrosion. Jut clean the hell out of both male and female sides with electric contact cleaner and something to scrub with. Mine didnt LOOK bad but obviously were.
I'm looking under the truck. I see 2 02 sensors each located in front of the two catalytic converters (is that right, there are two?) and these appear to be the only 02 sensors, nothing behind the cat coverters. Right away I'm confused because I thought I read there's one before the cat and one behind it... anyway I see two wiring harnesse, one for each 02 sensor. The one connected to the sensor which is closest to the passenger side contains a male/female connection point and then immediately leads into the wheel well. The other 02 sensor is only 6 inches away towards the drivers side. Same setup. These wires lead over the front driveshafft to I don't know where. I cant seem to trace either sets of wires to see where the grounding points are. BTW which of the two hoses on the valve cover are for the pcv, the one more drivers side? Thanks.
