CDL Woes
to eliminate bulb burnout, do they light up when you turn the ignition key over without starting to get the full dash christmas tree effect.
The center diff lock indicator lamp in the dash does not come on when you turn on the ignition key on a '97. I don't think it does in any models but someone should check the 91-92 models to be sure.
-B-
If the CDL bulb is out the ABS should come on if there is no wiring problem.
I just tested the indicator I have and it is just an on/off switch. So shorting the correct indicator should light up the CDL,ABS and Diff's if they are locked.
You could remove the indicator and feel if the fork has moved from locked to unlock. Don't know how hard it is with the t-case on the vehicle though.
