CDL switch snafu?
4383 Andes St Denver CO 80249
So I bought a CDL switch from a source other than Toyota and here is my dilemma: The 94 LC has the curved dash switches right? The one I got from the outside source (not naming names) is sure enough curved and marked as CDL. The plug for it that I found under dash was very close to a fit, but not quite right. I modified things slightly to make the switch fit just to see if it would work. I tried it and it did nothing in high range. When I put the trans case in low I got a CDL light on the dash when I pushed the CDL switch in and it stays on if I shift back into high range. It would not do this before I put the CDL switch in. If I then hit the switch the dash light goes out and will not come back on until I put the trans case back in low and hit the switch. I then did the 7 wire mod and nothing would bring the CDL dash light back on. Drat! so I put the 7 wire mod back to stock and it again behaves as described above. BTW the lockers come on and are actuated (not blinking but on steady) both frt and rr light up on the dash.
SOOO.. anyone have an idea as to what goes on with the switch? Did Toyota make a different one for 94 than for previous years and I got the earlier version due to a vendor mistake?
What is the part number of the switch you got?
I have a '93 and wanted the curved switch. People wanted too much for a CDL labeled switch, so I got another ECT switch (cheap). Works with no mods and fits right into the blank. I know this doesn't really help you out, but if you do decide to replace the switch you bought, this information could be useful.
The CDL switch itself has replaceable bulbs, just snap the CDL switch back out of the dash, or remove the dash panel again. Then unscrew the two bulb sockets on the back of the switch, the bulb sockets each have a slot in them that fits a flat blade screw driver, and replace the bulbs. If i remember right, i think the bulbs are $1.25 each.
I assume you are talking about the light in the instrument cluster that indicates the CDL being engaged?
On a 94 it is a bit of work.. the upper dash bezel has to come off before the cluster itself can come out. Decent risk of cracking said bezel in the process.
IMO it is easier to diagnose whether or not it is actually out by pulling the plug off the transfer case and shorting it with a jumper. This should turn the light on if the bulb is good and there are no other problems with the wiring.
If you get under the truck and find the front driveshaft, look for where the shaft goes into the transfer case. Facing the rear of the truck, on the top of this portion of the case sticking out at about 10-11 oclock a few inches back from the driveshaft flange is a large hex nut with a 2-wire gray connector on top of it. Remove this connector and put a wire between the two terminals. Dash light should come on.
Also, as to the switch not plugging in perfectly.. did you have to remove a tab inside the switch where the dash harness goes into it? If so It may be a relabeled Hazard switch. IIRC once the tab is trimmed it should work fine as a CDL switch.. but it has been a while since I messed with the 93-94 stuff.
