CDL Relay failed only one test
CDL does not engage when I go to low. 30 amp fuse is good. I installed CDL switch in dash, still no work. I pulled relay and tested it. It passed every single test except continuity between pins 6 and 7. No continuity either direction. This bothers me because it seems like there should be more than one item fail on the test series. With 9 volts applied, I hear the coils snapping the switches in and I get continuity everywhere I should. Any thoughts out there?
4L switch, Indicator Switch, Actuator motor?
Has it every worked or is this a new to you rig? Sometimes they take quite a bit of exercising (on/off). Even with mine working I didnt use it for awhile and had to "un-stick-it". I try and make a point now to hit the button every now and again between wheeling.
When testing the relay, were you putting the positive lead to Pin 6 and the negative lead to Pin 7? If so, you won't have continuity because there is a diode (electrical one-way valve) in that circuit. Try reversing your ohmeter leads and you should have continuity.
Nothing Happens
The rig is new to me but i know its history and neither of the previous owners ever went off road or would have checked the CDL. There is no whirring noise and I have driven in low range and know that the center is not locked by free turns. I check pin 6 and 7 in both directions and there is no contibuity either way. Does someone know how this problem alone affects the system? Can 6 & 7 kill the system? I have all other continuity on the relay and am trying to decide if I should condemn the switch and replace it or keep testing.
Pin 6 Not Connected to anything!
I think my CDL relay is fine. It passed all tests except pin 6 to 7 continuity. I don't have a manual and have been researching posts. The test sequence I found here must be for a different model. I found a manual page showing a diagram for my 96 and pins 6 and 8 are not connected to anything inside the relay.
So is it my actuator? From what I have read, the CDL indicator switch failure will only affect indicator lights and the front and rear lockers engaging.
If the relay isn't clicking when the CDL switch is pushed and/or low shifted, it is most often a bad contact/connection at the limit switch in the actuator. The limit stitch supplies the ground to activate the relay, so no ground, no relay click.
I posted some thoughts on trouble shooting on page 3 of this thread.
https://forum.ih8mud.com/80-series-tech/68015-cdl-actuator-fun.html
