cdl and pin 7 mod verification
Riverside,Ca
despite reading through hundreds of threads explaining the uses and benefits of these two mods i am still confused. I never let that stop me from getting into trouble so i went ahead and did them both today. had a lot of trouble with the terminals squeezed as i was into my footwell so i cut the wire. just to be sure i need some verification i did it right.
I should now be able to:
a) shift from hi to lo without the diff lock and abs light coming on on the dash.
b) engage and disengage said dash lights and the thing that control them at will.
Is that all thats supposed to happen or am i missing something?
Thanks for the help.
I can do both a) and b) i listed above. Lock and unlock at will and shift to lo without the light coming on. I have driven it but only on the pavement. Literally got done with this about a half an hour ago.
Sounds like you did it. Whether "it" will actually do anything for you or not, well only you know that.
Eh..... They are nice to have. If it helps me out once I'll be glad I did it. If not, oh well. Nothing like free mods though.
Being able to lock the center diff in hi range is nice, I haven't really run into a situation where having the center diff unlocked in low range helped me out though.
Low range unlocked is useful for making tight turns when wheeling.
This is a picture of a trail that is good for low range unlocked; I am loaded over 10,000 pounds, the substrate is marble so the detritus is also powdered marble. The turns are tighter and slope is steeper than shown, with a couple thousand foot drop off not shown on the right.
If you've ever "tobagganed" a truck, you'll know why the ability to run unlocked is crucial.
