CDL and Lockers
SoCAL
I hope someone my be able to lead me to the correct procedure. Can the CDL switch be pressed on the fly, or do I have to be stopped? Does the shifter need to be in Neutral or Park? Also on the lockers are they the same procedure to turn them on?
Thanks,
Great! what about speed? is there a max speed to engage them?
IIRC, the diff lock is inhibited from locking if the speedo reads over ~5mph. So going slow is likely a good idea? This is likely from the potential sudden change in handling when they lock, liability? The CDL isn't as important?
CDL can be locked on the fly at any speed. The owner's manual states not to engage front or rear lockers until the wheels stop spinning and not to drive over 5 MPH with the lockers engaged for safety concerns.
CDL at any speed, provided you are traveling more or less in a straight line so you don't shock load it.
Diff locks, on the fly at crawling speeds.Not sure why you would want to engage them at higher speeds.
They won't always lock immediately, but I find they lock when needed.
Same deal un locking. They won't unlock with a load on them.
In my 1994 owners manual, page54, it says before engaging the front and rear differential locks, and i quote "be sure to stop the wheels before locking the differentials" end quote. Then in red printing it says, quote "CAUTION= Do not lock the differentials until the wheels have stopped spinning" end quote.
Meh.
98.99% of the time, they won't actually engage until you are moving, and there is sufficient difference in wheel rotation across the axles for the locking dogs to line up and engage anyway.
If all wheels moving at same speed shift on the fly. I lift off the gas just because. when I lock CDL. I eliminate my anti lok braking I take it you have factory e lockers. Stop. doesn't matter what gear or range your in flip the switch,back up or move ahead until the light no longer flashes. Your locked in. It will some times take a bit(30-50)Mtrs or turn the truck sharply and move a bit. Unless someone else is paying the repair don't spin your tires aggressively and slam those pins in. Or you be doing this kinda axle swap. Always keep a donor close by
Yes, I have factory lockers. Very familiar with the axle swap. My cruiser did not come with factory e lockers and I was lucky enough to get one at a junk yard complete with harness. Did a bit of electrical troubleshooting to get it to work. Thanks for the heads up, I will take it easy when locking I really like this landcruiser.
Interesting about e probs. swapped engine n trans ran into a locker prob. No light came on when Tc locked by the tcl switch. So no locker operation. Harness fun to take out and replace eh.
So true, my first issue was that the rear was not locking. Come to find out the wires going to the rear from the front relay box was missing on my rig. I had to make a new harness and re-pin them. 2nd issue I had, relay box was chattering whenever you shake the vehicle. For some reason the wiring going to the cdl actuator was shorting with each other when you shake the vehicle. Ended up making a harness too.
But, I do love having lockers! when at the trails and we come across uneven terrain where one wheel just spins, lock em up and drive out! My friends have to take a different line or power their way thru.
It's fun to make it look easy when others struggle due to lacking lockers or they don't know how to 2 peddle!
Meh.
I guess if you have the money to pay to replace expensive parts you can do it that way. AS for me, I'll stick to following Mr T's directions in my owners manual, and pass on taking the risk of damaging expensive parts. YMMV
Ok, to clarify this. I'm not saying I have absolutely no mechanical sympathy for my gear. "Spin your tires aggressively" before the locker engages, then yes, you can expect to be doing an axle swap like @Burbot
Switching on lockers while stationary will not lock the diff in almost every instance.
You can not align the locking gear without some wheel slip, or difference in wheel rotation speed, that means lockers are engaging while the car is in motion regardless of following Mr Ts magical instructions when you flip the switch.
I've had numerous instances where I've flipped the switch, picked the best line I can, driven to the top of a climb and found the rear still hasn't locked because it wasn't needed, even after 200, 300, 400 yards. Front nearly always locks because steering gives a change in wheel speeds.
Watch your indicator lights, have some sympathy on the lockers until they are engaged. Don't be afraid to punch the loud pedal after they have engaged
