Long story short...I just put in a used transfer case as mine is currently having some work done and wont be ready in time for my next wheeling trip.
Once in, cruiser drives fine in 4hi and 4lo, but when I shift into 4lo I don't see the CDL/ABS lights go off and I cannot lock the CDL with my switch on the dash (7pin mod). After pulling the CDL switch/signal on the Tcase, I was able to jump the two terminals on the harness and get the lights to go on (so no issues from the harness to the switch). I could hear the relay clicking too when I pressed the CDL switch. I think the switch may be bad and am going to order a new one.
The other issue may be with the CDL actuator motor itself. Even if the switch is bad, you should still hear the actuator motor moving and it should lock up the CDL. Mine did not. I pulled it and put a 9v battery on the motor and nothing. I pulled the motor apart and there was a fair bit of corrosion inside and the motor itself looked a little fried. The pickups that spin the motor had 9v.
@george_tlc has some good threads on diagnosing the switch but I wanted to make sure this is the proper way to test an actuator motor before getting another.
