catalytic converter cut
well, well, finally the cats are plugging up, aside from losing my smog exemption, are there any negative effects of cuttin my cats off????, no i dont live in california, thanks for the info folks, 1994 stock unlocked mobil 1 white cruiser with glock stickers, 180000 miles:D
Probably lose some torque in the low end? not sure if crushers are the same, but generally speaking.
check engine light on permanantly.
less spark arresting?
Your 94 is OBDI. therefore the ECU will care less if the cats are there. I have a 94 also and ditched the cats a year ago. No low end loss at all. Seems to "breath" a little easier going down the highway vs. before.
Aside from the fact that the vehicle will be illegal to operate on hiway everything will work.
Ok
Im not going into cat/nocat thing but I would find out why they got clogged in the 1st place as something is not working just right upstream
That is correct! At 180k they should not be plugged. I was well into the 200s on my 94 and the cats were fine.
If you ever plan on selling the rig don't remove the cats. It is not fun going to the exhaust shop to get them replaced so you can sell it. And you'll pay dearly for them.
cat or no cat
well said guys. sounds like the ceramic stuff inside the cats is beginning to loosen up, bad rattling noise under there, this led me to believe cats are failing, thanks
x2. '94 here. also. If you're going to cut them off, keep them, and make sure you keep a stub of pipe on each end so you can reattach them later for resale/inspection/whatever.
