Caster readings not in range
Tierra y Libertad
Went to get a wheel allignment and this is what is reported:
CASTER Initial Numbers Left -0.1 Right -0.2
CASTER Final Numbers Left 0.0 Right -0.1
(Spec Min 2.0 Max 4.0)
TOE Initial Numbers Left 1.05 Right 1.15
TOE Final Numbers Left -1.15 Right -1.20
TOTAL Initial: -.10 Final: -.05
Back in 10/06 my then local mechanic installed the CC bushings (after my lift,) did an allignment and did not provide me with a report... First time getting alligned since then....
Proof that the CC bushings were put in wrong?
FWIW, I am getting an ARB bumper this weekend..can the added weight help?
Comments please...
Wish I would have know that in the beginning as I would have bought the plates instead of the bushings...
You have 850Js on that truck, no way bushings are going to properly correct the caster for that amount of lift. You need plates.
Yep your bushings put you right where they should for "j"'s. I went back to stock bushings and Rick's plates to get me in spec.
X3 on plates .. or at least blue caster bushings from Slee .. they will let you barely in positive side with J springs ..
I have J's and no caster correction (yet) and mine is:
CASTER Initial Numbers Left -2.7 Right -2.6
CASTER Final Numbers Left -3.3 Right -3.2
:eek: how you can drive it .. ?
It go straight with free steering wheel .? .8º diference between left and right ..
Dont have the OEM bushings anymore...Can I get buy with plates and keeping the ones I already have? Curious what the new reading would be now that I have a ARB bumper..
Hey latinoguy,
The weight on the front end with the new bumper will help....but not a lot. See if you can source some OEM bushings and get landtanks plates. Mine have been in for 6 weeks now and all is well. I posted a report of the final numbers, etc
Best,
Brad
