Caster Help
Winchester, VA
I installed F.O.R. 3 inch lift about 6 weeks ago, along with his 2 degree bushings. I had my front end aligned today and my caster is still way off.
Current measurments:
Driver Caster: -0.6 degress; center hub to flare: 23.5 inches
Pass Caster: -0.8 degress; center hub to flare: 23.625 inches
I am looking for the best and least expensive option to get my caster within spec. While pressing out the OEM bushings I caused some damage to them, so some of the options may require purchasing new OEM bushings.
Options I am aware of, just not sure will resolve the issue:
1) MAF drop brackets, OEM bushings. Will a DC shaft be needed
2) Landtank's plates, DC Shaft. Will OEM bushings be needed
3) Install heavy front bumper
Thoughts, recommendations, advice???
Thanks
slot the front holes 14mm which will give you 2 deg, and into + and make some 3mm square washers, put them under the bolts and weld them in place once you have rotated the front diff to the new location.
Check the rear steering arm doesnt touch the control arms, if it does, you can take the high spot off the casting where the 2 met in the mold, or press the steering arm from the knuckle and bend it slightly.
my plates will want the OEM bushings as well. I don't know the cost difference between my plates and the MAF drop brackets so you'll have to check that out.
I'm confident at that height my plates will correct the caster appropriately and if the drop brackets do the same then they also will need a DC shaft if mine does. That can be a wait and see kind of thing but if you want as smooth a ride as possible then the shaft is a given.
That heavy bumper will need to weigh enough to drop the front by 1.6" to bring the caster up to the minimum spec.
hope this helps
I installed Landtank's caster plates the other day, along with new bushings (Zero Degree) and had my caster re-measured today.
Old measurments (FOR 2 degree bushings):
New measurments (Landtank CC Plates; 0 degree bushings):
Driver Caster: 1.7 degress; center hub to flare: 23.5 inches
Pass Caster: 1.4 degress; center hub to flare: 23.625 inches
Steering feels much better with a heavier wheel that more readily returns to center.
I plan to install an ARB front bumper soon and imagine the extra weight will put me into spec of 2 - 4 degrees
one thing you might want to check is the clamps on the tie rod. If they are out of position when you turn the wheel they will hit the arms limiting how far the wheel will turn. It's not much but will effect the caster reading and give a false low result. Attached is a scanned image from the FSM showing how the clamp should be orientated.
