Caster Correction - Opinions?
retrofive
rɛtrəʊ
swfl
So after installing tires, lift and 25mm spacers, decided to get my caster measured, results below. My plan was to go with blue Slee's.
Running 285/75/16 mt's, OME med. 2.5", 851/860 springs with N73 and n74# shocks. Slee poly 25mm spacers front only.
Notice anything I should be aware of? or wrong choice in CC? It will be sometime before I go with anything larger than what im running now. If anything maybe 35's.
Let me know you thoughts, thanks!
Looks like your lowest caster reading is -1.2* so Slee Blues will get you to 1.8* which is just shy of spec (2*-4*). I think you would be fine.
I am running OME 850/860's and the Slee Blues are on my work bench ready for installation...
what he said. Going with plates would bring you on the high side of spec and then you would need a dc shaft for the front.
Now if more lift is in your future then the plates would be more cost effective in the long run.
Thanks guys. Think the blues will work out good with my current setup, just wanted to double check. Im happy with the lift level and not having to do all the other components (dc shaft, brake lines, plates) at this time.
Times will change and Im sure down the road someday I may take the larger lift route.
