Caster Correction for Dummies, Please?
Minneapolis MN
I've read several discussions from the search tool, but I'm not getting exactly what a caster correction kit will do.
I have recently installed OME 2.5" lift, with tires. I have a caster correction kit from Slee sitting on a shelf in my garage already.
What I want to know is whether I need to do this? Some say yes, some say no. What problems should I look for to know if I should add the caster kit?
From a mechanical standpoint, will a caster correction kit move the centerpoint of the axle/wheel forward or backward, when looking from the side?
I guess I understand a vibration problem from the driveshaft sitting at a new angle from stock. But from a front wheel perspective, I kinda don't get it.
Anyone able to put this into idiot-proof terms? :)
When you lengthen the distance between the axle and the frame with a lift, it rotates the control arm down which results in the axle shifting back as well as down. The caster correction corrects the axle from being angled toward the ground to almost level. This has nothing to do with visually seeing the tires pushed forward. That requires the control are to be lengthened.
I would say definitely do the correction. Here is a little article describing caster in particular:
http://www.off-road.com/trucks-4x4/old-man-emu-caster-correction-review-53359.html
If it doesn't drive too weird maybe you can live without it but that's up to you. Mine had 1" spacers in front and steering was a little "darty" for lack of a better term, especially when it was loaded down. My caster was just outside of spec. Removing the spacers put it right in the middle of spec and it drives and handles much nicer. The caster correction kit achieves a similar result (in a different way).
I personally would take it to a shop and have them get your alignment readings, this will include your current caster numbers DS/PS. This will give you an idea of where you sit now and how much caster you would like to add. Stock is +2* - +4*. Some like it closer to the 4*. With mine (using caster plates and about 4" lift am about 2.5*)
I did try to have an alignment done right after the lift. The shop said my adjustable parts are too rusted to adjust anymore. But they also said the alignment numbers all seems to be in spec, so adjustment isn't needed now - at least not from them. They wouldn't have been able to affect the caster they way the Slee kit can do, anyhow.
What were the caster numbers? Doesn't really matter if you like the way it drives. I know mine without any CC was darty, with CC bushing was better until I went up an inch and went to plates.
The bad part is that because they couldn't do the alignment due to the frozen parts, I never got a printout of the numbers. So I don't know what the caster is, according to an alignment rack.
At least I didn't get charged for it!
Just to get the numbers wouldn't need any adjusting. Try a different shop. I have read here that even some Toyota dealers will do it for free. I took mine a local ma & pa shop, gave the guy $5 for his troubles and printed out everything. No adjustments made. Just the numbers as it sat.
The only thing most shops will adjust is toe, so most likely the threads on the TREs are stuck. Very common. Penetrating fluid, heat, and lots of hammering MAY solve that. YRMV! They should of been able to give you current setting values even if they did not adjust anything.
not all shops have a rack with the ability to read caster. Might sound weird but I've ran into quite a few.
Also until you reach 4" of lift the axle is still forward of the stock position. This is due to the fact that the factory set up the trucks to have the axles position 2" higher that the rear frame mount. So as you lift the truck the axle moves forward until it passes through the 2" lift mark where it then begins to move rearward back to the stock position at 4" of lift.
  • Like
Reactions: ppc
I was just looking over my paperwork and I guess I did get the numbers from the alignment rack.
So in reality based on those numbers, installing those Slee CC bushings you have, should bring you right up to spec. I would do it. :)
I think you would find it drives better down the road.
I don't mean to hijack the thread but when I got my cruiser the po claimed it had the caster correction done 9 years ago with ome bushings. When I looked at the bushings they were black not yellow but the bushings did appear to have an offset eye. Do oem bushings have an offset eye? I would like to figure out If I have oem bushings or some kind of after market caster correction
