- Joined
- Apr 21, 2005
- Threads
- 115
- Messages
- 25,823
If it would make it any clearer I could snap a picture with the PTO gear that goes behind the transfer case input gear.
I'm not disputing your knowledge that the pictures illustrate a Fairey overdrive.That will not fit with a Fairey overdrive on the back. The Fairey overdrive for the one piece transfer case does not interfere with the side mounted PTO. If you what for looking for you can see the Fairey PTO gear on one of the pictures.
Some observations:
(1st part you already know) in 82 when Toyota went to the one way PTO gear box on the side of the transfer case they changed the PTO winch worm gear to wind the other way (I forget which way) so if you have a late model one way PTO gear box you must use the post 82 winch worm and wheel set so you get 5 wind in gears and one (slow in reverse) wind out gear (and not 5 slow out and one "fast" in as I did).
(2nd part) from the 82 change date the winch drive yoke from the shaft to the worm gear and the shear pin also changed, and at the same time the pin number went from 90255-04001 to 90255-04002, and it looks like the later pin is the same material but about 1/4 bigger in cross section, from about 4mm to 4.5mm. the Yoke change would be for the thicker pin hole. My guess is that Toyota re-did their sums and found that they could still be safe with a "more useable" stronger shear pin.
The parts I am working with are all old and very worn so if someone has good parts to measure I would like to know if my guess is correct, cheers from Australia
