Carburetor
Czech Republic
Hi everyone.
I am new here from Czech Republic. I need help!! I do renovation of my fj40 1966. F135 engine. I have 1BBL carburetor on it.I would like to replace with 2BBL.Can you recomend suitable one? IsTrans-Dapt 2020 Performance Carburetor adapter suitable under it? I do not want Weber carburetor as I want to use original air filter parts. Thank you Vlasti
There is an adapter from the Weber to a Land Cruiser air cleaner. I don't know if it actually fits the early air cleaners and intake manifold heights.
I like the Weber, but the 2-barrel adapter doesn't make much sense as far as a plenum design. It really doesn't match the Land Cruiser fuel pump. The accelerator cable route isn't easy.
I've no experience with early Cruisers, so maybe someone else will chime in.
Welcome to Mud.
Carburetors don't really wear out, aside from the soft parts, and getting dirty.
The one thing you may have to repair on the 1bbl after 50 years is the small link that connects the accelerator pump rod to the throttle shaft. It’s a small, kind of horseshoe link that takes a snapring one one end.
Word to the wise: if you get a rebuild kit with ‘hard’ parts (jets) DONT USE THEM UNLESS YOU HAVE TO. They are often sized differently than the original, and often make the truck run worse.
@Vlasti take @65swb45 advice for sure. He knows of what he speaks.
Good luck and welcome.
