The black hose in your pic looks like it is connected to the top front center of the carb, where the port comes out for the power piston-power valve. It was originally routed to the VSV [smog stuff] that told it when to open the power valve.
If it is plugged off, there's a good chance your power valve may be open all the time. Not a good thing. If you say that it runs better that way, there's a chance that someone's tampered with the carb in attempt to compensate for this.
The correct solution would be to provide a good vacuum signal that holds the power piston back during normal operation but allows it to engage under heavier loads and throttle. Direct manifold vacuum from one of the plenum runners for or aft of the carb is NOT a good source, because they hold a higher vacuum than inside the venturis of the carb, which are closer to atmospheric pressure.
Hth
Mark A.
