Carb Starting Issue
Inland Empire, Southern California
1971 FJ40 stock US carburetor. The LandCruiser does not start unless I pour gas directly into it. Once it starts it idles fine. I noticed that at starting, no gas is spraying, however once started the gas squirts fine. Where in the carburetor should I check?
Sometimes the choke plate sticks Marty, make sure it is closing when you pull the knob.
With engine off, look into carb and pull your throttle butterfly. You should see a powerful squirt of fuel. If it’s a weak stream, you may need a new accelerator pump. The stream give a priming squirt at startup.
Might also be good to check is your vacuum numbers once your engine is warmed up at idle. If vac is low, fuel won’t get sucked into engine at a optimum level. I’m at 18.5hg on my 71, it starts instantly.
