carb question
How many ball bearings are there in a stock 7/77 FJ40 carb? See pic, this is the upper air horn hole where the power piston goes and it appears there is a ball bearing in it, is that correct? I cant get it out if it's supposed to come out and in all the diagrams I've seen, it doesn't look like there is supposed to be a ball bearing there?
I don't think there should be a ball in there. The power piston is a needle valve I think. If you have compressed air you could try shooting some into the main jet. Should blast the ball right out. Put a rag over the power valve hole first though.
A lot of times ball bearings are pressed into bores to seal them from the factory. That looks like a factory job.
