Carb Problem
Delaware
1979 fj 40
My automatic choke does not seem to be working on a cold start.
Any suggestions?
New member Jim
Not sure.
Engine is trying to start, but the choke is wide open.
Shouldn't choke close when cold, and when it warms up the choke should open up?
Thanks
The choke is not automatic; there should be a cable and a knob on the dash for it. Pull the knob all the way out for a cold start, don't touch the gas pedal. When it starts, you can move the choke knob in a bit at a time so that it idles good until it is fully warmed up.
Maybe that's the problem, I do not have a manual choke.
I do have a small electrical wire (12 volt) to the carb. I thought it is for a automatic choke.
Does anyone know if I need to install a manual choke for a 1979 FJ-40?
yes you do need to install one. You can get a manual choke cable for about 8 dollars at tractor supply or a similar store that will work
Thank you!
Any idea what that electrical wire is? It has a snap-in connection that goes through the firewall.
You sure you have the original carb? Picture would help!
I think so.
Putting on a new one that has the same set-up.
Wish I knew how to post a picture, I'll ask my 30 (I'm an old guy) something children.
the old aisan carbs had an electric idle solenoid (that might be your wire and plug. it does go to the firewall.) that takes care of the idle so you don't have to manually adjust it. then you'll need a manual choke to help at startup. (or if your vacuum goes out.. 😕 ) that being said you also want to make sure your vacuum is good and all the hoses are hooked up.
Thank you.
I do have an old aisan carb.
All hoses are hooked up, so maybe it is the vacuum.
Can you give me an idea where it is located and what it looks like?
The vacuum is on the driver side, bolted on the lower side of the engine. before you go down this rabbit hole, make sure you buy a choke cable and try it with the choke. (photo is from Cityracer LLC's site)
You'll need a choke cable plus something like items 30 & 31 in the link above. I got a pack of three different types at autozone.
