I know my carb is running rich and some of my rings are in bad shape.
How is the mixture controlled when driving or not at idle?
I have a lot of blow by so this is getting fed back to the intake which is causing it to run richer. So it seems like it would be a constant cycle as the engine gets older more unburnt fuel is getting back to intake with the same amount of gas coming into the intake causing it to run rich?
Would changing the jets to a smaller size lower the amount of fuel getting into the engine? It seems like on a perfect engine hardly any unburn fuel would be recirculated and the mixture would be good. But with a less than ideal engine how do you tweek the carb to adjust for the added recirculated fuel.
I am trying to understand how the carb works.
