Carb Help NEEDED
Orlando, Fl
ok, so, we get a 74 carb out of a 72 worked on by a mechanic we know, and it winds up.... the rod and butterfly valve in the secondary barrel.... are from a celica of some sort, so... heres a few pics, and what should we do? is there any where we can get a new rod and valve, if not, does anyone have one they are willing to part out or sell the parts?
It is a later carb than a 74, because of the vacuum operated secondary. It looks like a '75 CA model because of the thermal sensor on the base.
Why not just put the butterfly back on the shaft. Usually it is a good idea to leave them on the shaft because the screw ends are peened, but you should be able to get new screws.
If not, just get another rebuildable carb. that would be easier and cheaper than trying to get the correct parts.
The one thing I really learned was not to take them screws off when i was building my carb. They have to be brass screws and they are very hard to find. My dealer could not even get them.I know this did not answer your question, just something i learned the hard way.
just my .02 cents
well, as i've been told, dont take the screws out, but thats ok when its the wrong butterfly valve and rod, so i wasnt too worried about it getting messed up, and so, since i had the parts numbers checked, its a 74, unless the top is to a 74, and the base is to a 75. anyway, is there any company that has individual parts to these carbs? or am i better off just buying a holley or weber carb?
Jonathan/SandRider - Ryan/BigBlue
I don't understand why you say the shaft and butterfly is wrong. It looks perfectly appropriate for an Aisan vacuum secondary '75 carb.
If the rest of the carb is missing or belongs to an incompatible year, just get a rebuildable Aisan core and rebuild it. Toyota has the shaft screws.
Go to sor.com and check out all the pictures of the carbs to ID what you have.
The problem is that the rod is too short because it came from a celica or some other car...what we need is a new secondary rod and butterfly valve...because the butterfly valve that is on this rod came from the other car also...its kinda confusing but basically the end of the secondary valve that is suppose to connect to the primary..the throttle side...is to short because its the wrong and therefore my carb isn't working properly...i know its confusing sorry ..haha
as you can see in the first picture...about how the rod is too short..
If your fuel bowl matches the throttle body you have pictured, you should just pick up the vacuum secondary for the 75-79 carb and call it good. That shaft you have already has the mounting point for the secondary diaphram.
The earlier rod would not have anything to link to on the primary anyways. :)
So if it doesn't link to anything then how does it work..and why does it appear to not be working..
The little pin sticking out of the plate on the right hand side [the one with the cocked spring next to it] is where the secondary diaphram attaches. THe other end of the diaphram screws into the side of the fuel bowl on the 75 and newer carbs. The diaphram is actuated by vacuum, so the secondaries are vacuum actuated, not mechanical.
Don't mess w/ it
New Rider / Sand Rider
Quit screwing w/ it and send it off to 65swb45(Mark) for rebuild. I can't say it enough; Mark is great w/ these carbs. Don't get caught up w/ it like I did on mine. The smartest thing I ever I did to my carb was take it off and send it to him :idea: . If you doubt me, search the board, he's great w/ these things.
Thanks again Mark, you do great work ;) . Now get up to the Con' and the first couple of :beer: 's are on me.
Just a happy customer,
Campy
