carb float needle valve
Boise, ID
I think this is called the needle valve. When I went to adjust my float, it sprung across the garage before I got a look at it. Is this picture correct? The flat end goes out (down), and not the pointy side? Are there only 4 pieces, the body, the spring, the needle, and the brass spring insert thing?
Thanks... :beer:
Thanks guys. It looks like I've got all the pieces and got it together correctly. The float level is out of control though, it basically fills to the top of the bowl. I need to go take it apart again and see whats going on.
If the needle valve is not working you will know it. Might
be dangerous as the fuel pump will have nothing to tell it
to stop and your carb might fill the intake with gas.
Be careful.
If it's just the float level too high, you need to bend the
float down so it "turns off" sooner. I've heard the experts
say that the cruiser runs about the same as long as the
float level is within the sight glass; up or down a mm or
so won't change anything.
As for adjusting the float level, if you have an old
fashioned toilet, you'll know what I mean.
Another possibility: you've lost the little aluminum washer that seals the seat of the needle and seat assembly and your seat is not sealing to the airhorn. In that event, the float and the needle will do their jobs, but gas will continue to come into the carb via the threaded part of the seat. :doh:
Verdict?:confused:
Thanks for the replys. I got it fixed. The new needle valve wasn't working correctly. I put the old one back in and now have the fuel level perfect.
I do have a new problem now though. It now idles like a champ, but when you step on the gas it sputters and starts to die. Let off on the gas, and back to idleing like a champ. If you pump the gas pedal a few times you can rev it up. I can drive around with the choke on and it actually stays running, but as soon as the choke is off it starts to die with gas. Ideas on this one? I verified that the accel pump is shooting gas out when the throttle is hit. Maybe not enough gas? The fuel level stays at half way, so the fuel pump seems to be doing its thing.
:beer: Tim
Check that all vac lines are connected and you dont have any leaks first. I would personally also check to be sure spark plugs are clean and all ignition components are working. I have a toyota engined forklift that runs like that when the plugs are fouled from too much fuel.
The accelerator pump may be a little late. You can adjust that by bending the actuator lever.
Ed
I think it should start squirting fuel just as ot slightly before the throttle plate begins to open. Maybe Mark will chime back in and give you more definite advice. You can verify when it is working by looking down the throat of the carb(engine off) and working the linkage to see when you get the squirt vs when the throttle begins to open.
Ed
