Carb/Air cleaner replacement and snorkel info request
Eugene, OR
So.. reading about the Weber carb replacement, I am leaning towards keeping it Aisin, so the City Racer made in Japan aftermarket will do. For now. As a Sniper carb is the endgame, but I have to deal with exhaust and other leaks first, so maybe some day.
However, I like the idea of replacing the stock air cleaner housing and replacing for a more 'snorkel friendly' air cleaner, I've seen folks in here using barrel style "BJ" air cleaner assemblies (on the left of the engine bay) to accommodate for a snorkel, and then run the air intake into the carb.
What setups are you running on a 2F? I'd like to see your pics for some ideas, as well I'd love you read your suggestions. I'll try the Search in here in the meantime, but the search is atrocious. Sorry Admins :(
Thanks!
I had to lose my stock air filter to mount the power steering pump, found a couple pieces off the shelf at Napa to make something that sorta works...
