carb adjustment?????????
Orlando, Fl
First off....thankyou to all who helped me with the idleing problem...I got that taken care of. I got the idle solenoid valve hooked up and got the timing perfect as well as the rpm's right at 600. But I got a question...When I accelerate slowly in first, the truck lurches alittle bit...it like shakes; feels like its pulling itself. Also, it sometimes slightly backfires at random times(although not at an idle). and when it does backfire...its just a little tit tit tit out the carb. Do you guys think this is a slight carb adjustment that needs to be done with the idle/air mixture screw or what? I'm clueless...any comments are more than appreciated! thanks again
//newrider
Perhaps a lean idle miss? Maybe try enriching by turning the idle mixture screw OUT a turn or two and see what happens...
sweet...i'll try that out...any others???
A turn or two is a lot to let an idle screw out usually. I'd try quarter or half turn incriments.
I tried to mess with it some...it still wants to backfire. When I press on the accelerator barely...it almost stalls. It's backfiring out of the carb and the exhaust. Do you think the timing could be off even though the timing ball is right on the arrow?? thanks guys
Maybe.
Does the BB move if you increase the RPM?
Also, eyeball the accelerator pump...
