On your truck you can lock/unlock the center diff with the dash button when the transfer case is in HIGH range.My 1991 fj80 diff light is on and when I pushould the diff. lock button nothing happens. I hear a click from the kick panel by my left foot but nothing changes. what would be the proper test to tell or deduct what the problem might be.
The center diff will automatically lock and stay locked when in low range regardless of button position.
You do not have ABS on your vehicle.
You do not have a viscous coupler in your transfer case.
You do not have front and rear locking differentials in your axles (assuming they are stock).
Make certain the transfer case is in HIGH range for normal driving with the DIFF LOCK button off.
Chock the front tires so the truck doesn't roll and kill someone.
Put a floor jack under the rear axle and get one rear tire off the ground. Release the handbrake.
Grab the rear tire that's off the ground and try to turn it. If it's locked in place then the center is locked. If it rotates easily then the center is open.
The AT/P light will illuminate on the dash when the transfer case is in NEUTRAL and the TRANSMISSION is in PARK. This warns the driver that putting the transmission in PARK will not prevent the vehicle from rolling.
