Can't unlock transfer case
Alabama
My 1991 fj80 diff light is on and when I pushould the diff. lock button nothing happens. I hear a click from the kick panel by my left foot but nothing changes. what would be the proper test to tell or deduct what the problem might be.
There is a 4wd switch and indicator switch on the trans. They are plunger style that can get seized. Not to hard to remove. One is at the top 12' position and other about 30* over. (sorry been some time since I remove them to clean). That and there is a fuse and the less likely switch failure.
I had the truck on a lift not long ago doing brakes and bearings. the arm that you are referring to at 12 I couldn't move. so do I need to remove and replace to free it up. also even though I hear clicking assuming the switch is working I have no lights on the button. all other dash lights are working
Just as a double check - you might shift the transmission from drive to neutral a couple times to make sure there's no bind, then get back at the CDL / trans case.
But like @retrofive said, it prob needs a bit of a service, then if you don't already, find a gravel lot near home where you can do a monthly excercise of it.
Would having to push the shift lock button to go from park to review. or drive be some kind of indicator
Arm? THere are 2 ball plunger type switches. See the pic in this thread. Or search for more, there are tons of diag the system.
Technical help needed. 93 center diff lock issue.
I don't know the permissives on a 3FE gen CDL, but you have to have the trans case in low range to automatically get the CDL to kick in a 1FZ w/o the pin 7 mod.
I was just thinking you aren't getting any CDL so a few "bumps" of the trans output shaft to jockey everything a bit might help.
Or if you're on a incline and have some driveline bind & it can't move at the moment.
IDK, another 3FE guy can answer - but do your guys' systems need be in Low range in the transfer case to get a CDL to lockup?
Calling @jonheld and @LS1FJ40 for diagnostic assistance.
I am thinking a low tire causing bind in the drive line not letting it release.
Can also rock the steering back and forth while rolling to help it release.
Otherwise, I got nothing.
The CDL can be engaged in high or low with the 91-92. That's one of the reasons all of you newer 80 owners envy the Mighty 3FE!
I'm not an expert by any means but this sounds like the plunger switch that @retrofive mentioned. I haven't had a problem with my 92 but my 93 had a similar issue. I replaced it with a switch off Amazon. I'll post a pic of it. It's a 10 min job. I believe you need a 27mm box wrench to do it as you can't get a deep well socket and ratchet in there. IIRC.
The clicking you hear is the relay opening. If it was mechanical (binding or something broken in the center diff) I would think you would hear grinding or binding noise.
Didn't see this...
Isn't this the neutral safety switch (NSS) failing? The shift lock is an override of the NSS. Isn't that correct? Anyone?
No grinding or noise just that the light is on on the dash and will not go off.
Sure as hell sounds like the switch on the center diff. The one I posted above. You can take the other one out, spray it with carb cleaner and try to get it to free up then plug it back it. I got mine to work after messing with it but I had already ordered the other one so I put the new one in anyway.
I just noticed that I don't have the abs light on that I have seen mentioned. I will pull the switch out and clean it to see if that helps
No ABS in 1991-1992. Not until 1993.
The CDL switch does not put it in to Low. On the 91-92 you could lock the diff in High or Low.
You can also do this in 93-97 if you add the switch and do the pin 7 mod. The 91-92 came from the factory this way.
