About 3 months ago i replaced the master cylinder on my 91 and bled everything per fsm. The brakes were good at that point, it was driven for a few weeks with no issues then parked till a few days ago when i got in and nothing....no pedal at all. I inspected everything and found no fluid leaks the master was still full and fluid clean. I tried to do a quick bleed with my vacuum pump just to try to get a pedal and i cant get it to pump up at all. The drivers side front showed tons of air bubbles coming out the others a little but not like the ds front. What points in the system would let air in but not leak? The new master was an asian but not oem could this be my culprit. This is the reason i replaced the master in the first place. I checked the ds caliper real well and like i said no leaks. can over time the brakes slowly release and let air in but not leak?
