- Joined
- Aug 18, 2006
- Threads
- 15
- Messages
- 63
I'm trying to put two Mr Gasket 1" spacers on the top of the springs to correct the Stink Bug look (and low headlight shine) I got from installing an ARB front bumper. Did a search, and what little I could find sounded like an easy job...
Got the wheels both off, the sway bar disconnected (tire has to be off and ARB line must be loose first so you can get the bolt out), and was just barely able to pry the spring off (did not "fall right out"). After putting the spacer up in there I can't even come close to getting the spring back in.
So... I put down a deposit on a spring compressor, which doesn't work because it goes inside the spring - it would compress the spring just fine, but the spring won't go on because of the cone the spring goes around...
I need a spring compressor that is two parts and goes on the outside, but no one in town has one. I was able to use the one I got for one side of the spring on the outside and a scary homemade thing on the other side, but still not even close to going in. I think I could get the spring back on this way - if I took the spacer out!
So, unless anyone here has any ideas I'll put it back together this afternoon without the spacers and order an outside-the-spring compressor online and try again another day...
