Cannot lock my front diff for axle rebuild--Problem?
Columbia, MO
I'll try to be brief...
I'll be performing my front axle service soon and have heard to lock my front diff before starting to make it easier to put the axles back in BUT, perhaps more importantly, to prevent the dog clutch from "dropping," which would make for a very bad day when I tried to put the axle back in.
For reasons I have not yet discovered, my newly acquired '93 is missing the wiring harness for my front diff lock and even if I had the harness, I'm doubting the actuator will actually engage since it's been open to the elements for so long by the PO's.
So, do I order the harness and try to get the actuator working first to avoid a horrible day? I've read posts where locked 80's were kept in the unlocked position during the axle service because folks simply didn't realize they should have locked them.
Your thoughts?
Thanks.
--Mark
As I recall, you should be able to pull the locker (or part of it) and manually lock the axle. Not sure of the exact procedure.
If you get the harness and get the locker working, I found an easy way to lock the front axle without fear of having it locked on pavement...Granted I was pulling the 3rd member for a gear swap and had to drop the front driveshaft anyway BUT, with the front drive shaft out and the front axle up on stands a simple turn of the dial and slight spin of one tire and the front axle locked in about 1/2 a second :)
The other option is to take your chances and do the axle service without locking the front axle....Not sure what the success rate is for those that didn't lock the front and not having problems.
I've stabbed axles into an unlocked e-locker, it's not that big of a deal. There isn't much slop in the cog, so it's not likely to "drop" down and get in the way. But, if it comes down to it, yeah you can manually lock it by unbolting the actuator and sliding the rack gear over with a screwdriver. You'll probably have to fiddle with carrier position by slowly turning the pinion while you push on the cog. Just don't forget to manually unlock it afterwards, or steering will get very difficult!
The front does not need to be locked.
Thanks for the replies...
So, nothing at all I shoud be aware of since I won't be locking it? Saw a few posts on this with no definitive answers so I'm just trying to learn and cover my bases. ;)
--Mark
If Cdan says you don't need to lock the front axle then you don't :)
Thinking back (has been a couple weeks now...LOL) I may have had to lock mine because I was pulling the 3rd for a gear swap...
