Can you help me
Please somebody to help me,have this toyota from 15 days,ATT A442Fmworking only in manual mode-2,3and D,not working speedometer,tachometer,cruise control,first gear'L",touch down button,only some conn4ectors stay empty from ATT,please send me a some help im my e-mail lucke@abv.bg.
Thank you verry
I'm sorry but I can't make any sense of what you are trying to say. Do you know someone who speaks English a little better to help us out?
He has a 93 HDJ81 with a A442F and it won't shift automatically - it has to be moved between gears manually with the stick. The speedometer, cruise control, tachometer, and kick down switch for the transmission don't work.
what does he mean by connectors staying empty?
The A343 has a speed sensor in the tranny as well as the one mounted at the transfer case. If the A442 has the same setup then I'd think one of his connector at the firewall where they plug into the main harness is bad. CDan mentioned that someone lost his PHH and it dumped antifreeze on those connectors and it screwed up the shifting pretty bad.
