Can the 2F??
Hollister, CA
Website
www.bww.com
Hey guys, I'm about to completely rebuild my engine and I needed some information. Maybe I shouldn't be asking this question ,but out of curiousity I just need to know.
Can the 2F run on synthetic after it has been fully rebuilt?
Comments and opinions would be nice.
Break the engine in on a quality oil, at least 5K miles, and then switch to synthetic....
I have had good luck with standard Rotella 15w40, Castro 20w50 or Cat 15W40 engine oils, and do not see where a synthetic would benifit me...
Good luck!
-Steve
Good luck!
-Steve
thats also what i run
My 2F is just happy to have oil.
I wouldn't bother with synthetic in an 2F motor.
Just not worth it IMHO
Every 2F I have ever seen leaked.
Synthetic will leak even more so.
Just throw 20/50 dino oil in and call it good.
It makes as much sense in a 2F as it does in any other engine. 2Fs don't have to leak anymore than any other engine.
That said, I see no reason not to run petroleum oil in my engines. Keep it full, change it when needed and you won't be disappointed, even with inexpensive oil.
Mark...
I'm surprised to see such poo pooing of using synthetic in a 2F:
Synthetic flows better into smaller spaces and handles heat better than conventional oil.
2Fs have main/rod bearing heat damage concerns when run at highway rpms. #5 & #6, usually, as Mark W. has stated in TT.
Therefore, synthetic would provide superior heat protection to the 2F's Achilles Heel.
Also, synthetic no longer leaks more than conventional oil. That was a '70s concern when early synthetics didn't have seal sweller additives.
You know, this is exactly what I thought. Isn't heat and viscosity breakdown the enemy of all engines(I sound like a commercial) because from reading sooo many posts and searches this seems to be the achilles heel of the 2F.
When I was younger I had the priveledge of working for a semi-pro racing team. Everything mattered to those guys, but they paid attention to the engine the most and were using 20w oils to keep the engine at optimum temperature. This is why I asked the question in the first place
Don't you think they used 20Wt for lower flow resistance (less power loss), much like modern engines spec 5W-30 for better mileage?
For the record, my 2F does not leak any of the dino oil I put in there when I change it every 2500 miles (although I'm knocking on wood between keystrokes). Unfortunately, my 1FZ is another story . . .
