cam gear removal
ok, got the cam out of the engine... i want to take it to the machine shop to see if they can weld it and do a regrind, but the darn gear is pressed on... really well. (i did take the snap ring off, too...) once i get it off, is it going to be that hard to put it back on? i have a 3 jaw puller that i got from auto zone, but i've read another post that said that the guy bent his trying to get the gear off. will i need to put it in a press to get the gear back on the cam? see the pic below.
gear with puller
gear with puller
A shop press works best, same for insalling it...
Generally, you don't want to use a puller on hardened gear teeth if you don't have to (and you don't). If you can't use a press (best), support the back of the gear on top of the jaws of a 6 inch vice (or equivalent) and whack it with a BFH and a drift punch.
Use a press. Doubtful that a run of the mill machine shop will be able to regrind your cam. Pretty specialized job.
Mark...
Poser said:
To put the cam gear back on the cam....just heat it up a little bit, and it will drop right on the cam.
x2
Put the gear in a coffee can about 1/2 full of motor oil, stick it on the stove till it gets hot (outside camping burner or grill preferred...)
Drop it on the cam then break out the beer and burgers.:beer:
I knew a guy that heated one... and 500 miles later the rubber dampner ring failed....guess he should have set the oven on medium-rare insted of well-done...
I just stick it back in the press used to remove it and push it right on. Simple, quick, clean and easy.
Mark...
