Caliper won't release
Truckee, Tahoe, CA
I just installed some new DBA rotors and pads onto my cruiser, and on the passenger side I can't get the caliper pistons to back off of the stock pads. I've searched and didn't find anything. A neighbor said maybe the cylinder had rusted?
I'm going to try to hook it back up to the flexible hose and pump it full of fluid, but i doubt it will work.
Please help!
Anyone?
Front, rear?
To lube my front caliper pistons I removed the the pads, put a thin piece of cloth in there to protect the rotor and then mashed the brake pedal repeatedly until the pistons pushed out. Then I pulled the rubber boot back and put grease on the pistons. Pulled the piece of cloth, used a c-clamp and screwdriver to push the pistons back in, then reinstalled the pads. I think you could do this with the caliper removed as well, but be careful since I think the pistons could come all the way out and you dont want that unless you're planning a full r&r of the caliper.
ps- Make sure to have the brake fluid reservoir closed when mashing on the pedal, and open when pushing the pistons back in.
Hope this helps.
[EDIT: just re-read and you cant get the pads out. Take the reservoir cap off and try prying the heck out of them with a screwdriver through the holes and see if you can get them out. If you can get them out, then maybe lube the pistons up]
Sorry, maybe its still useful info.
Sometimes the pistons just get cocked in the bore of the caliper, and you basically need a c-clamp or something similar to push them in. Be careful not to mess up the bore or the pistons will not seal like they should.
If all else fails, get a new set of calipers at Napa (where they were a decent deal last time I checked. You can also buy caliper rebuild sets from Toyota for not a whole lot of money.
Try the c-clamp thing first.
That happened to me on my rear caliper. I dont know how it happened, but the freakin brake pad slipped out and the actual "piston" was stopping the brake rotor.
Eventually it was "cocked" stuck. Might not help, but an experienced worth speaking about.
Thanks everyone, I am going to connect the calipers to the flexible hose, and mash the brake pedal and see if that works. its the front btw.
any advise on removing the front rotors? which bolts do I take off?
All of the ones in the way. :lol:
Your question is along the lines of "What color is black?"
Two 17mm from the inside the are about 1 1/2" long.
