If you change the rotor, caliper and dust sheild you should be able to. I have all of the parts sitting in the shop to go with the post ~8/92 brakes on my 90 which have the same front caliper piston size, pads and master cylinder bore as the pre 8/92's so no worries there but I am waiting for 37x17" tyres and 4.88 gears first.IS IT BACKWARDS COMPATIBLE?
I mean can I put 93's on my 91? you know calipers and rotors?
sooooo. that means yes. I can put the bigger calipers/rotors on my 91 without a problem and better braking?????
You will also need 93-up knuckles. The caliper mounting points are different.
