- Thread starter
- #41
Thanks much for the encouraging words. This has gone way beyond rational but owning one of these already qualifies that. This truck was my daily driver 15 years ago and now it just does dirty weekend duty and home depot runs. I guess you are right Output Shaft, its just a big boy puzzle and there is the challenge. Big picture is I hope to keep it going long enough to take my 5 year old son on many trips to the desert.
The actual numbers for the last 5 fails are:
I agree about the charcoal canister although I have wondered if somehow it could not be venting the carb bowl, giving pressure and therefore extra fuel.
The big "what if" in my mind is the "computer" but not sure how it would send so much extra fuel. The very close rpm but different speed makes me wonder if some system is being triggered although I would assume the rollers have more resistance at 25 mph.
I did the lean drop per the FSM with the air cleaner off and the HIC plugged, I may see if I can lean it out more with everything assembled. leaning out the idle is the only significant thing I did between the last two tests although I had discounted this due to the off idle test.
I do feel like I am winning the war as I have sealed, tightened, repaired many little things to get it running nice even with the EGR hooked up. the frustrating part is knowing it could be one simple adjustment that makes the difference and there is no way to test the emissions at home.
Thanks again to everyone for all the help.
