I just had an Alpine stereo installed in my '97 LX450 and at low volume there is a buzzing from under the dash in the area where I believe the amp is located. The installer doesn't know what the problem is. From looking through Search I found that there is another plug for the speakers that goes around the amp. Should I pull it all apart and use that or try something else? Also, I saw in another thread that the power line isn't that strong, should I run a new power line? If so, do I go direct to the battery with a fused line, and what wire is it that I would be replacing?
Thanks in advance!
Randy
Thanks in advance!
Randy
