Buyin', Sellin', and Tradin'
Pics as promised...
My wife's IS300, we have owned it since November of 2005 when it had 40k miles on it
2002 Lexus IS300
120k miles
auto
every option but Nav
Sunroof
Dual power front seats
Aftermarket cd player
Timing belt/water pump, all belts, hoses, fluids, etc. done at 95k miles with Toyota parts
Good Toyo tires
Metallic grey exterior, black interior
Asking $7800
Located in Auburn, AL
Call or text, DAYTIME only, DO NOT call or text me after 7pm, 334-850-0613
I need a Toyota "EFI" emblem (needs to be from an 80s 4 cyl 4Runner) if anyone has one or stumbles across one. I'll throw 20 bucks out there if anyone does.
I've got one but not sure if it was from a 4runner! When I get done holding the baby ill head to the garage and take a pic. Rance
Sam Stewart said:
Think I might have found one Rance. I'll let you know.
Sent from another Galaxy
Probably not what your looking for but...... Tabs are broken off the back too
hey rance, I'll take that quarter though. I'll give you 15cents for it, it's a few years old and may need alot of work.
Losing proposition bro. You'll have to put another 10 cents in just to get it running. So unless you think it's going to be worth 30 when you get done...
Story of my life! SMW (shake my wallet)
I have a set of front fenders off of a 3/76 FJ40 that would be good for a trail rig as-is or a DD with a little work. Asking $170
I also have a tire carrier that is available (spacers not included) - $100
I am willing to negotiate on some of these items and some are firm priced... ask if you are interested in something
SOLD I have a 27' long Penske truck body to be used for storage for sale near Royston GA.... great to store your extra cruiser parts... a great deal at $800
It is completely flat inside, no wheel wells to trip on,
the roll up door locks and could use a few more bolts in some of the hinges, but operates as it should the way it is now.
you must deal with moving it.
I bought it where it sits and never had an issue with it leaking, but noticed a few tiny holes the last time I was looking at it... caulk and 10 minutes will fix it right up. It is sitting on some poles and should be structurally fine for the move. But I did not pick it up to look under it, it feels very solid from the inside.
It has a fiberglass roof that lets some light in....
SOLD SOLD SOLD
I also have 2003 honda rancher with 280 miles and 70 hours on it..$2700
Adult owned 2 wheel drive four wheeler. Only minor scuffs and one 1" tear in one of the black fender flare parts. Battery was bought from the Honda dealer, (not a crappy Wal-Mart battery) in October maybe November or december or January, I am not sure....but it has been VERY recent...maybe even February... I will look for the receipt if it is needed. I had the carb. and gas tank cleaned and the idle needle valve replaced in February 2013. Tires are great, everything works perfect, looks like new. Has been kept covered except for the rare time we got caught on it in the rain. Electric shift.
I new Barbour Jacket with liner Size 52, never worn. I think Orvis charges about $500 for this set up and I am selling it for $325.
Cedar gun cabinet for $150 SOLD SOLD SOLD
fj60 hood for $100 good shape, needs repainting, one small ding in front SOLD SOLD SOLD
100' roll of brand new 12.5 gauge horse fencing 5' tall (new 200' is around $340 at tractor supply...) $140 SOLD SOLD SOLD
I have about 20 T posts that are between 6-7' tall SOLD SOLD SOLD
I have a few axles and wheels/tires and a hitch you can make trailer out of for hauling things around the yard or if you are really good you could make a streetable trailer... these came from a large boat trailer that was being modified.. $200 for the set up (2 welded axles and 2 wheels/tires and hitch)
Engel fridge and freezer Combi 65 with both cords $750
I have some blacksmithing post vises and a few coal forges too... $35-$150
a couple of sets of rusted out ambulance doors for $50 for the set (for hardware and glass)
A few sets of pretty good ambulance doors for $200 for a set
2003 Kubota M5700 4wd tractor, 679 hours, GREAT shape, hood has a dent and one corner of the canopy is broken..
HST Hydraulic shift transmission, means you can go from fwd to reverse without pushing in clutch
$22,000
6’ Rhino bushhog, very heavy
6’ box blade with scarafers, slight bend
3 pt hay spear-homemade
3 pt tool pick up,-homemade
Quick detach FEL with 6’ bucket, reinforced and has a hook for a ½” chain, and a detachable tooth bar
Flexible pasture harrow (professionally made like a heavy chainlink fence with points)
Front end loader fork lift attachment
Front end loader hay spear, one small point has broken off
changed all fluids and filters per manual
Canopy with one small break in it,
Fold down Roll over protection
One set of rear hydraulics
Industrial tires, no repairs or plugs, filled with water
8 fwd gears, 8 reverse gears (but I do not recommend using all of those reverse gears)
OLDER Miller Spoolmate power source with OLDER mig spool gun, NEW electronic control panel $1000 gun looks a little rough, but works fine. includes regulator
fj40 bibs-1978 and 1981 (rectangular) $75 and $100
radiator cradles $20 each
NEW fj60 gas tank $500, as far as I know they are NLA from Toyota
4 speed transfer case that needs to be reassembled and rebuilt $100 obo, it is from a 1975 fj40
fender skirts $20 each
1972 Fj55 frame, Drum front axle/Rear axle/springs, steering gear box $750
1976 Fj40 frame $500
Fj80 third row seats $100 for set, has some cuts/marks on the underside plastic..
Fj80 rear light protectors $30
NEW TOYOTA 87 60 rotors $200 set
1972 55 gas tank, needs cleaning $100
Fj40 Plastic gas tank $100
78 fj 55 hood $50 dented and needs work, but better than nothing SOLD SOLD SOLD
gasoline powered air compressor I believe it is 5hp gas motor, $400
large Microwave $25
200 used wine bottles 25 cents each
small steel cutting band saw $150, on stand, horizontal cutting… 120v, but could be modded for vertical cutting too
Older and some newer Playboy magazines…. Collector items <wink> <wink> $1 each selling as a whole “LOT” maybe 140 magazines
Weller Solder gun $15
Portable Ryobi table saw, never used, $75
======================SOLD SOLD SOLD
1978 fj55 runs and drives, has typical rust and lots of surface rust, but the floors are great, fenders are the worst... complete and stock (except missing some rear interior panels and has the wrong wheels), has warped rotors, but I have a set of cheap autozone rotors in the box, steel gear for rear window, stainless battery tray, new aftermarket speedo cable installed
carb has been rebuilt but needs adjustment, gas tank was removed a year ago and cleaned and I ran all the gas out except about 1 gallon before parking it..$3500 SOLD SOLD SOLD
Paint Arab cross horse with tack-GREAT trail riding horse...NEEDS to be with a buddy..$1800
Smaller Mammoth donkey, will chase dogs and coyotes...$600
will sell them together for $2200
homemade 2 mobile home axle trailer about 15-16' long, not really good for hauling a car, but good for other stuff, wood floor, pockets on the sides, 2" ball hitch, spare tire and rim, no fenders, has screw jack in front for getting it off the car hitch, $750 obo
a few kind of crunched fj40 fenders for $20 each, better than nothing...SOLD SOLD SOLD
fj40 stock roll cage $125 no pads SOLD SOLD SOLD
1976 fj40 frame $500
1981 2f has less than 100 miles on rebuild but has some scoring on cylinder wall #1, (still has honing marks in the cylinders-(I think a ring was stuck when I restarted it, or it dripped a valve and the shop did not grind it out all the way) and 95% of everything needed to make it a 2fe, (I think I missed one section of wiring, and 2 fuel injectors and MAF) includes transmission and split transfer case, alternator, carb, intake and exhaust with down pipe, smog pump, thermostat housing, water pump,, power steering pump and gear box, sitting in a frame cradle I made (NO 2f head) but has ALMOST all the 3fe parts intake/throttle body, head, sensors etc ...$1500 obo
mated and planed intake and exhaust from a 1978 40 $150
NEW TOYOTA mirror heads and arms and mounting brackets, telescoping round head $300
NEW TOYOTA fj40 upper dash for a 78 40 $250
make an offer on anything you see here, all of it (except the Penske truck, gasoline powered compressor and band saw are located in Dewy Rose GA) is in Royston GA...
I have more parts and stuff for sale,,,,, but I think this list is long enough :hillbilly:
pm me an email address if you want pictures
Oh I wish I could buy this truck...might see what I could do when I get back from vacation. Bout to have 2 yougins and want to raise em in the woods. I was green with envy with this rig when I wheeled with you in the Whee. Really need a 4 door rig that is capable for most the trail riding I do. I loved watching this thing in action...
Will you take payments lol..:hhmm::idea::lol:
Just missed it! Sold yesterday. That was a great trip!
Now I need a 40... $10k range. Wheeler that can get me there and back. Gotta be something out there?
