Buy Sell Trade
Is the input shaft for a H motor or a B motor? That would make a difference to people pondering this.
I've got a pair of ARB's sitting on the bench, so $$ is gone now. Too bad.
Greetings, I have an acquaintance out here looking for front fenders for a 60 series, he has a FJ62. Anybody got something kicking around?
Hey Phil,
Andrew has a spare or two front fenders; I'll see what his plans are (one driver, one passenger). :beer: @Ajhj60
:beer:
Cleaning up some of my collection of stuff... as usual OBO or trade or ?
Roof rack with gutter mounts.
No idea the actual brand but it looks like the ones in this UK websitehttps://direct4x4.co.uk/products/aluminium-front-basket-roof-rack-toyota-landcruiser-2 but is definitely steel not aluminum. Arb style knock off that is decent quality. I mounted it on my 80 for maybe a month then took it down because I just want a flat rack not one with the front bar. The 80 gutter rails are probably the max width you could do with it. uses 3 mounting feet per side, I swapped out the steel fasteners for all stainless hardware. $650
80 series radius arms with ARB caster bushings. Maybe 4000km on them. $200
Billet battery clamps with multiple bolts for accessories $100
Waterport day tank. holds 14L $150
Warn sidewinder for winch $50
On board air setup kind of a home made puma setup. Works great but I have installed a york so it's time to let this one go.
Extreme outback 1/2 hp continous duty compressor with a brand new piston and head. Mounted to a 3 gallon air tank. Powered by a viair solenoid. Fully ready to go just add power.
$350
Compressor, tank, solenoid, bolt down as you like
Or....
$400 compressor, tank solenoid and bracket that mounts into the LH 3rd row seat location on 80 series. Doesn't stick out past the wheel well so doesn't effect ddrawes, fridges etc.
And he only needs driver side, he would take both, depending on price
@Granite Grinder $100 drivers side only Andrew needs the passenger side. just surface rust. I'll let you know if either of us are heading up your way or you can pick up down in Abby?
Anybody got any leads on a FJ60 Top hatch?
I keep checking at EBI and they got nothing.
Stripped down BJ74. Frame is from Vancouver truck. Rust is surface. Very viable frame. Asking $750 for the frame. Fuel tank attached.
Front axle. 3rd is not available. I’ve got the axle shafts in a box. OME springs attached. Not bad shape actually. Rear springs aren’t available but weren’t as good $500
Body is picked clean. Too rusty to be of any use but if someone wants floor or any of the metal come get it. Take what you need/want. Cut as required. No charge
Don’t look too close. That tailight is garbage.
^^^^^To above parts. Just got called in to cover people at work. Gone until late June. Any interest let me know here by pm. It’s in Ladysmith and easy to see if anyone wants to look. I just need to know to make arrangements to see. Chihuahua’s aren’t big but they are mean and I don’t want anyone to get hurt.
